Hello to all,
I've looked through the fuel system/fuel injection threads but haven't found an answer to my problem so I'm posting here in the hope that some of you may have some ideas.
My RV7 Quickbuild ( IO360) is almost ready for engine runs and hopefully first flight. I fuelled the airplane for the first time this week,about 10 gals. a side,
and checked for leaks,no problem from tank to Andair selector valve. However fuel does not flow from the selector outlet to the Airflow Performance pump downstream. The installation instructions for the pump state that the pump must not be run dry, so though I've run the pump for about 10 secs. it does not pump fuel. The pump package is standard as supplied by Vans with the exception of the fuel filter ( I replaced theirs with a Flow Ezy ILA2 40 micron filter that I had from another project) and is installed as per their plans.
I have a fuel flow transducer for my AFP 30 installed between the pump outlet and the firewall ( as per the AFP30 installation instructions)though as this is downstream of the pump I imagine it shouldn't affect the operation of the pump.
My questions are:
- Do I need to "prime" the fuel lines through the fuel selector to start the pump pumping?.
- Is it possible to wire/run this pump in reverse?. I wired red to 12v and black to ground.
I have checked and rechecked the "plumbing" of the selector and the pump installation and they are as per plans.
Any help or ideas would be much appreciated.
Many thanks
Mike
My questions are:
Many thanks
Mike
