Vlad
Today I found this hole on RV8 fuse. Does anybody have tips and tricks how to cover it? I want the patch look nice.
Vlad,
I cut out a piece of Aluminum and patched it. I also used "proseal" to insure no water would infiltrate it.
If memory serves me right the Flap fairing covers it up.
Vlad,
Ha! I don't have plans with me so that hole was there? For taildragger? :confused:
Hole
The Flap fairing covers it completely . The flap fairings make no sense until you fit the wings and flaps . Can email you some photos , one 666 to another .
-8 step hole cover
Here is how I plugged mine. There has been some threads suggesting that the hole be left open since the flap fairing covers it. To me that leaves a place for air intrusion. Notice the blue mark where I expected the fairing to land. Stay outside of that line.
I just cut a circle of .025, curved it until it fit nicely inside. Made it a bout 1/4" larger than the opening and prosealed it in place. No rivets, super easy, after a few days it's nicely stuck in place.
There will be no test.
It has been a few years now from when I saw this on a test, but. The answer should be in "AC-41.13". If you go buy it, you will be covered.
Yours as always R.E.A. III #80888
That is exactly what I did too...
Put a landing light in there Vlad........ that way you can see where you are going when you're doing a ground loop at night!
