Goal:
To fly with 0 aileron trim
Scenario:
You're going for a soloflight in your side-by-side RV and you're ready for fueling.
To be able to fly the RV with neutral aileron-trim, how much more fuel would you put into the tank with the empty seat?
(assuming you don't need full tanks for the planned trip ofcourse...)
Or said in another way: assuming you take off solo with no imballance in the tanks, how much lighter would you make the side you're sitting on before starting to use the other tank?
(and from then on you'll feed equal amounts from both tanks ofcourse)
Scenario:
