Flyingfanatic
Member
In my quest to learn as much as I can about building an RV, I've read a lot about build quality. Despite searching these forums, I haven't seen it defined (which I'm sure is a matter of opinion)
How is build quality defined?
Is it the riveting? How well the skin is installed (no gaps, etc)? What tells you if something is built well?
Thanks for all the info so far. I look forward to learning more.
