pa38112
I have Bendix 500514-1 mags with the wiring harness removed. The harness can be rotated to any position. There is no label that I can see identifying which lead is #1. Is there a way to identify on the magneto which lead is for #1?
On my mags
On my mags, the #1 is clearly marked on the cap where the wires come out. The harder part seems to finding the next cylinder to fire since that depends on whether it is a right of left mag.
I just used the pictures in the Lycoming manual to wire things up. I’ll make sure everything is right before first engine start, once I getbthe prop on, break the engine preservation, and start rotating the engine.
I have never seen a Bendix mag harness that could go on more than one way. Most of the ones I have seen have the spark plug number stamped on the nut for the spark plug that it routes to.
The following image is out of a Bendix mag overhaul manual.
