cytoxin
tried my best to fix the spinner to cowl gap turned out pretty good.
![](/community/proxy.php?image=http%3A%2F%2Fimg205.imageshack.us%2Fimg205%2F5918%2F1001566it8.jpg&hash=9917d2820fc5d24c61b3078d16988a00)
small layer of rage gold.
![](/community/proxy.php?image=http%3A%2F%2Fimg205.imageshack.us%2Fimg205%2F2930%2F1001577so7.jpg&hash=d67f548767784e084cd944538ab4a371)
gap was not paralell at the joint and was 1/8 wider than the other side. now its much closer but still a touch wider. the engine may sag some and make it perfect. :?
![](/community/proxy.php?image=http%3A%2F%2Fimg205.imageshack.us%2Fimg205%2F5826%2F1001579rh2.jpg&hash=19b7295b51b63cf86bf86aa09a6f9d3b)
pinhole ****. after much research i figured the best way to go was as vans described in their instructions. so i dutifully washed and sanded the cowl.i mixed up a batch of 105 resin and 205 hardener.did not thin. i applied it with a chip brush but that wasnt gonna cover the whole cowl.(4 full pumps of resin)so i got a bondo squeegee and spread it with that. i ended up with resin back in the cup.
ohhh btw think your cowl is flat :roll: think again.
![](/community/proxy.php?image=http%3A%2F%2Fimg292.imageshack.us%2Fimg292%2F4784%2F1001581ci0.jpg&hash=062118ba906c1c4372630b0818b9e32a)
i sanded this with 80 grit then epoxied it with straight resin. here it is after 3.5 hrs (cutting the grass.) dried nicely still a little shy about the acetone. my SPONGE brush is still rubbery. i will try it on a small test piece soon. thinner would be better I WILL NOT USE THE FOAM BRUSHES AGAIN.
![](/community/proxy.php?image=http%3A%2F%2Fimg205.imageshack.us%2Fimg205%2F6666%2F1001583ty3.jpg&hash=1baa380c8f57b8f2fd3877f461bede8a)
after the first sanding with water...note the changes in color. thats where the low spots are. got them out later.
![](/community/proxy.php?image=http%3A%2F%2Fimg205.imageshack.us%2Fimg205%2F3851%2F1001588zf5.jpg&hash=3a58e5d4a2e1713edbf0232ec3ba80b0)
well several hours of sanding this stuff and it was very smooth.(wet and dry) a few low spots but no pinholes. vans method seems to be the trick for me. i have sanded many paints and primers but beleive me the epoxy ot tougher than them all. not as bad as everyone says but, that would depend on your stamina and experience. i could have sanded a camaro to a 800 finish ready for paint in the time i sanded this cowl.
once i get the bottom half done i will prime them with k-36. i may first prime them with DPLF epoxy primer. maybe not. i already bought it however.
![](/community/proxy.php?image=http%3A%2F%2Fimg87.imageshack.us%2Fimg87%2F7091%2F1001591ne2.jpg&hash=4c95c07074971d9c7551d76811325779)
