I look at the winds & if I can get the same groundspeed by going higher, I climb. My plane does roughly 200mph TAS at 10k & 170mph TAS at 16k, so If there is 30 knots more tailwind in the high teens, I climb. The fuel savings ends up being about even with the O2 usage.So how do you know if its worth it?..I mean we all know an RV is happiest (i.e best speed in still air for least fuel flow) at 8 to 10k'
Yup! They're addictive - just don't look at it when you're doing aerobatics.... is to check the miles per gallon readout on the EFIS.
What is the highest altitude anyone has been in a RV9/A?
I look at the winds & if I can get the same groundspeed by going higher, I climb. .
OK I must be slow this morning Bryan..But why would you climb higher to get the same groundspeed?...Is it because you use less fuel (cus you got less mp) ...??
Frank
Exactly Frank - if you can get the same ground speed, but burn less fuel doing it,. your trip is less expensive AND, you might be able to eliminate a fuel stop, which will REALLY make the trip faster (extra range is a very cheap way to increase your trip speed). That's why I use the mpg read-out to fine-tine my altitude.
Paul
Good question cus I'm going to Denver from Western OR next month and I got my new altitude demand O2 system and there are some firece westerly's up there this time of year..
What would be your calibration for going to say 14, 16, 18k?...is a 20 knot tailwind worth flogging up to 18k on say a 3 hour X country?, assuming a typical price to refill the O2 tank etc.
Frank
Run the flight plan on duats at a few altitudes and see which one is fastest.
Eastbound, going high is usually a good idea. West not so much.
Duats will save you gas and time.
DM
Anyone know the record?
Some guy in a 150/152 did somewhere around 50 spins over Burgstrom ?sp? in Austin IIRC.
It is Barb McLeod that Paul is referring to. She has video of a 52 turn spin she did but I can't get it to work from the web pageI'm sure that Louise will chime in sooner or later....it was a GAL (Louise knows her - writes interesting music...) in the left seat of that 150/152 over Austin (there was a guy riding along in the right seat counting) when they did the 50 spins....![]()
