When I put the two halves of the fuse together I fashioned a rotisserie and have had that arrangement. I'm almost ready to be done with that and put the engine mount and wheels on. For that the rotisserie needs to go. I am going to build a wide sawhorse to put the forward fuse on because I hadn't needed one before.
I'm going to put the wheels on before doing the canopy and engine placement.
I have a shop crane to do the lifting.....
How high is enough to let the legs get put on without dragging the ground?
Where on the fwd fuselage is a safe good place to place it?
