RVG8tor
I need some help. I just did my first priming on the skin with the Sherwin Williams P60 wash primer. I've been told to keep it light, but as I sprayed it, it never seemed to coat. When properly coated should the surface be opaque, if so I am doing something wrong. As you can see from the pictures the entire surface is somewhat translucent. It is like the color is not fully mixed. The surface feels like it is entirely covered, but it sure does not look like that. I sprayed most of the 4 oz of primer I mixed up trying to get the surface totally covered. I do not want to add more weight than required for good corrosion control, so any help would be appreciated. The photo make the coating even look lighter than it does in real life.
I shot this with a small touch up gun bought from Harbor Freight Tools, this may be part of my problem, I did not want to use a large gun for such a small amount. It might be my adjustments to the bun. I am not sure how to set the air and pain flow on the gun. Thank in advance. I think this is good enough for corrosion control, I hate to add more to the surface, it I do I will use the rattle cans I have used for the ribs.
Cheers
![](/community/proxy.php?image=http%3A%2F%2Fimg128.imageshack.us%2Fimg128%2F3291%2Fimg1377iw7.th.jpg&hash=9b7432fde58fa5aff2f57f8a382c8d30)
![](/community/proxy.php?image=http%3A%2F%2Fimg219.imageshack.us%2Fimg219%2F8210%2Fimg1378nh0.th.jpg&hash=2e5ba9d734ee832d4e91adf0aeb452f6)
Cheers
