jdcoleman73
I'm New Here
When you file your flight plan most people know to file the type aircraft of a cessna c-150 as a c150 or a piper warrior as a pa28 but how do you file an experimental aircraft such as a Vans? Most file with the abbreviations of "EXP". The homebuilt market gaining strength there is a new way to differentiate the capabilities for you to file your flight plan. For homebuilders the correct way is to file HXA, HXB or HXC. What that means is, Homebuilt experimental "A" "B" "C". "A" is a homebuilt that has a cruising speed of less than 100 kts, "B" is a homebuilt aircraft that has a cruising speed of 100 to 200 knots and a "C" is anything over 200 kts. There is also a climb/descent speed that is based into that, but I am leaving it out for simplicity. What that means is, if you are going to file a flight plan or the air traffic controller ask you your type, for those of us that fly a vans aircraft the correct type would be HXB. The letter after the slant is the equipment suffix. If you have a transponder with mode c then you are a /U. This can be found in the AIM. This is a new category and maybe new to the air traffic controller you are talking to. It is updated in the computer system and will be recognized when you file your flight plan. When you get to the first person of the ATC system they may ask you to "verify your type" then when you say RV-?; they will say "Roger" and chances are they will have no idea what you are flying. I am am an Air Traffic Control Chief, I am a multi-engine commercial rated pilot, air traffic controller instructor and former flight instructor. Any questions you have I would be happy to answer.
