mgomez
How do you drill the rudder blocks to the fuselage?
I can't see how I could possibly do it without an angle drill with a long #10 bit. I'm sure I could make the first bold fit
, but I'm sure the other three would not.
I assume the way people are doing this is by match-drilling the blocks to the fuselage angle, which (at least once the structure above it is installed) requires an angle drill. Maybe this is a "Quickbuild only" problem?
Martin
Martin
