UnPossible
Ok - dumb question. I have a Garmin G3X system and a GDL-39. I've had ADSB in for a while, but just installed a GPS A20 to get ADSB out.
FYI - the A20 is only hooked up to the 23ES transponder (I'm not using it as a GPS source for the G3X).
I am getting a solid green light on the A20, but is there anyway I can tell that the 23ES is getting the GPS signal? Is there any configuration I need to change in the G3X steup menu for the 23ES?
I am hoping not to have to put the plane back together, test it, then take it apart again if something is amiss.
Jason
Jason
