JackinMichigan
Today I did a VFR flight to an airport I've never been to. To keep my nav skills sharp I plotted a course old school using a number of VOR stations to navigate, keeping my iPad and GPS handy as a backup. Moments after takeoff I dialed in the first VOR station and - nothing. No signal or audio identifier. I switched around to other stations and was able to read them, but not the one I was most counting on for this flight. This is the second time I've experienced this (different VOR last time, and it was down for 3 weeks).
How do I know if a VOR is inoperative BEFORE I plot a course relying on it? Is the FAA just allowing these things to fail? Are they in the process of obsoleting them? Just wondering if I should stop using them all together.
An inoperative VOR should be NOTAM'd out. You can check NOTAMs many ways before flight. The Foreflight briefing has an enroute navaid section which should show it. If you are old school, you can call 1-800-wx-brief and get a briefing there. They will tell you.
Here is a clunky FAA site that lists NOTAMs.
https://pilotweb.nas.faa.gov/PilotWeb/
Thank you.
I did call WX Brief just before takeoff (mostly for weather and visibility updates) and this wasn't mentioned. I went on the website you linked me to and discovered, if I'm reading it right, that particular VOR was decomissioned over 2 years ago.
I guess my next stupid thought is - why is it still on the charts?
Thank you.
Many pilots seem unaware that once a notam is published in the official notam book, it may be removed from the 'teletype' circuit. The FAA thinks that everyone subscribes to the notam publication. You may call FSS and specifically ask the briefer to look up that vor (or an airport, or...) in the published book. Otherwise, you only get the most recent ones. Some airport managers are wise to this, and keep re-issuing notams to keep them 'alive'.
Hash marks
Hi Jack,
Are there hash marks through the frequency information for your particular VOR? According to the chart legend, this indicates that the navaid has been shutdown. Take ECA, for example just outside of Stockton, CA. This shows up in the VFR and IFR low/high chats.
I also found this article which discusses the FAA's plans on decommissioning VORs.
So pilots with approved gps navigators can still use it. May have victor airways running thru it.
I have wondered in the past why, in this situation, they don't convert the VOR to a five-letter RNAV waypoint. Some have been done this way, for instance, when the Tyrone VORTAC (TON) was decommissioned, its location was replaced by the waypoint TYROO. Not sure why these don't get converted as soon as the original navaid is decommissioned.
TON still shows up in digital data sets, and on some charts, but on the VFR and IFR FAA charts, it has been replaced by TYROO.
A useful tool
This is what we use in the military. https://www.notams.faa.gov/dinsQueryWeb/
If you want the notams along your route, scroll down to the tab that says "flight path search". That should help out. Also you could just do a search for a particular VOR and see if there is anything for it. Let me know if you have any other questions.
VOR
If the identifier is not being transmitted, the VOR signal should not be considered reliable.Of course thats not before but should be done when tuned in.
Bob
