Sierra Delta
Member
My 9A has a problem. I thought I had correctly drilled the two alignment holes in the WD-605 elevator horn that attach it to the F-790 elevator pushrod. Now,the left elevator is flush with the horizontal stabilizer and the right elevator is 1/8" below the horizontal stabilizer. The skins are riveted on. How do I fix this mistake?
