Bending hinge pins
Depends on what kind of bend you are making, as a basic 90 degree bend can be done "cold" if the radius is kept moderate. I too have a -4, and for my cowl side pins I made a full loop approximately 1/4" in diameter that accepts a screw at the forward end for retention. For that bend, I heated it red hot and bent the loop using rounded needle nose pliers. It will not affect the strength, however it will ruin the cad plating (gold color) and make it more subject to rusting. I used stainless hinge pin for mine simply becaue I had some, and dont heave to worry about corrosion. Some hinge pins are hardened and very brittle...bending without heat may cause it to break.
