mvidalr
Hi all,
I'm having trouble trying to sleep, and couldn't find a post related to this issue.
Place yourselves in the early stages of wing construction. For those models with the W-731 type AEX stock tie-down bars, the drawings (15A) call for tapping the hole for the tie-down ring 1 inch deep.
This 1 inch is not enough for the ring's shank to travel til stops, therefore leaving about .478" (15/32") threaded shank exposed. (Pics below)
Is this excess normal? Is there also a "best" orientation for the ending ring (parallel/perpendicular to airstream-EVEN IF only used when grounded)?
Or should it stop at the W-731 TD bar like this? (credits: www.rv7factory.com)
Am I overthinking this because there will be something between the TD bar and the base of the TD ring that I'm not aware of?
Thanks folks
![5de6e0f1950cd4e9c2567ca8bb2e3d7c_zps6a050cff.jpg](/community/proxy.php?image=http%3A%2F%2Fi1070.photobucket.com%2Falbums%2Fu483%2Fmvidalr%2F5de6e0f1950cd4e9c2567ca8bb2e3d7c_zps6a050cff.jpg&hash=0a28e7fd3ae87ea88d68afebf99c377a)
![78761b44e4054f9313aeb8ad300e6cf8_zpsd342cb14.jpg](/community/proxy.php?image=http%3A%2F%2Fi1070.photobucket.com%2Falbums%2Fu483%2Fmvidalr%2F78761b44e4054f9313aeb8ad300e6cf8_zpsd342cb14.jpg&hash=4a85546842122fd17ec2d374b82293b0)
![826d00204e594007f5f2c141f0d2ab9b_zpsae05f194.jpg](/community/proxy.php?image=http%3A%2F%2Fi1070.photobucket.com%2Falbums%2Fu483%2Fmvidalr%2F826d00204e594007f5f2c141f0d2ab9b_zpsae05f194.jpg&hash=e8bbb9974176c0181ed2087e388bb0b0)
Thanks folks
