Winter is approaching quickly up here North of the 49th. OAT's are about 30-40 degrees F and my inflight oil temps are around 150.
Today I partially covered over the oil cooler with an aluminum plate and this brought up the oil temps to 170.
I want to be able to adjust the oil temp while in flight with a cable, much like the cabin heater.
I saw somewhere, where a fella put some sort of a "T" valve in the line leading from the engine to the oil cooler. On to this he attached a cable where by in cold temps he can shut off the oil going to the oil cooler.
Will this wreck anything ? Anybody know where I can get such a "T" fitting ?
I checked Aircraft Spruce but don't see anything useful.
Thanks for the help.
Darren
Darren
