Paul Eastham
This has happened to me three times now, wondering if other people have experienced this.
Carbureted engine w/ stock Facet boost pump.
On a hot day, after flying around a bit, shutting down, and then preparing to restart shortly after, my fuel pump does that really loud "I'm pumping air" banging noise prior to engine start. It doesn't go away on it's own, I usually just turn the pump off, start the engine normally, then verify that it's gone back to it's usual quiet hum after starting.
I guess fuel is boiling in the gascolator (just upstream from the pump), and the vapor is stuck at the pump since the engine is not running?
The concern, I guess, is vapor lock that bites me right after takeoff.
I have a blast tube on the gascolator but obviously that doesn't do much on the ground. All fuel lines firesleeved.
Thoughts? Speculation?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
