Would you be interested in flow divider to injector hoses instead of rigid tubing?
Tom
Tom
Tom
Tom
Gary, thats actually one of details to work out. Obviously the ball seat hose ends would need to be developed. We were thinking about it for about a year, after some of our fellow RVers had some rigid injection line failures.
The biggest obstacle is the hose ends, so obviously some cost analysis would need to be done. I have 2 versions prototyped, just havent gotten back to them.
Tom
Can you get hoses that have as small of an internal cross section as the 1/8" SS lines? If you double the ID of the tube / hose, that doubles the amount of fuel that can boil off after shut down, and could/would make hot starts more difficult.
Larry
Actually, doubling the ID quadruples the volume.![]()
In our SDS injector hoses, we (and Ross) use -3 hose with .125 ID, but the stem ID is .079. WE have seen any issues with that.
Tom
LOL---you are much better at math than I am. And YES---there are alot of things to consider. I wasnt trying to compare an electronic injector to an open orifice style mechanical one. BUT---in the SDS system at 40+ psi the return is on the fuel block, not the injectors. So single line to each injector. I would think that there 'might' be some residual fuel left in the injector hoses--well at least some that didnt vaporize similar to a rigid tube.
So is the residual fuel 'cooler' because its in a teflon liner and not a stainless tube? Gee-I dont know, but my feeling is yes, but to what point, I dont know. Sounds like some thermocouples in a hose port to test the fuel temp would be a fun exercise, but under what conditions?
Gee---sounds like we need a test plane. If only mine were finished---not anytime soon!
Tom
Thank for pointing out my limited math skills.Good to see someone keeping me in check.
Do the rigid lines fail very often? I've never known one to fail, but my experience is limited to a handful of installations in the certified world.
