Came to the same conclusion.......Thanks, that makes sense.
Was a little uncertain based on the instructions not having the -6 in step 5.
Picture to help.
Let the games begin. Hit a little speed bump right off the bat.
-Does anyone know what holes step 5 is referring too on page 08-02?
-This spar requires priming as its not alclad, correct?
https://www.dropbox.com/s/8sp1g573e1bcjhq/IMG_3185 2.JPG?dl=0
I'm by no means an expert at this airplane building stuff:), but if you go the horizontal stab section of my blog and scroll down thru the pictures (just after C-Frame pics), you'll see a a picture showing the rivets you had a question about.
I have to read every step about 5 times..and sometimes still mess it it up:)
Have fun.
Talking about the 4 holes in each HS-912 hinge bracket.
The powder coated parts need to have the holes drilled to fit the rivets.
