I have been measuring and re-measuring the location of the bend relief holes in the horizontal stab forward spar and I'm pretty sure that I have the mark in the correct place. However if I open this out to 1/4" with a unibit (as per the instructions) then there is no way I will have the edge distance from the hole that will be drilled for the HS-00003 doubler.
The previous posts that I have looked at are from before the introduction of the doubler that is causing me the problem. Has anyone else come across this problem and, if so, how did you resolve it? Does the relief hole have to big as big as is mentioned in the instructions?
