I have an ECI kit engine IO-360 with hollow crank .On first flight I started getting oil on the windshield so I landed and lost 4 qts of oil in 2 min. I found the crank plug turned 90 deg in the crank, replaced with a new one. With 5 hrs on the engine while doing a run up I blew the plug again. Things that I know oil pressure max 70 psi ,plug installed correctly,very smooth running, crankcase breather open.Looking for answers.
