Preparing to match drill the set of hinges that form the seat back attachments to the seat floor. The aft most hinge gets 3 additional holes that are picked up through the seat ribs, but when I laid out the hinges per the dimensions on the plans, I noticed the holes that I've predrilled in the hinge come far closer to the holes that get picked up through the seat ribs. In the worst case, the two holes on the right (inboard) side would be only about 5/32" apart from one another. I have verified that the hinges are in fact 15.5" long and the holes I've drilled in the hinge are as called out in the plans. Anyone else run into this?
