Does anyone know if the two holes, one on each side serve a purpose?
Depends.....
If a builder finishes the panel as designed, those two holes are where the pilot and copilot cabin heat controls mount. The panel sections will have a small notch that fits around the control. This allows removal of the panel without having to disconnect and remove the heat control(s).
Thanks Scott. I was curious because the prototype doesn't have that.
