I have a quick built fuselage. While fitting the cabin top I just noticed a series of holes, not dimpled, but in the series of set flush rivets that follow the door section in the fuselage. There is a total of 14 per side, starting from above the rear vent, then following around the door and then up along the front door channel. Is this for something later? Or is it pay back from the workers in the Philippines.
