I recently looked at an RV-6A for sale which has an HIO-360-B1A engine with a little under 1300 hrs SMOH. I believe the engine previously came out of a helicopter. I have no prior RV experience but this seems a little odd to me. What info I've been able to find indicates that the primary difference between the HIO-360 and the IO-360 is that the HIO redlines at 2900 RPM vs 2700 RPM and the TBO is 1500 instead of 2000.
Anyone out there have experience with these engines? It's nearly at TBO now and an overhaul would likely cost about the same as on the IO-360 but would only provide 75% as much usable time afterward. Doesn't sound like a very good idea.
Any idea how much to replace it with an IO-360 at overhaul time? Other options? Thoughts?
Thanks!
Thanks!
