The oil temp on the 14/14A runs somewhat hot compare to other planes but your temp is very high, even for new engine. As a reference, my oil temp on my first flight was in the 210-215F range. Your CHTs are also higher than I would expect for a IO390, even as a new engine with the OAT of 63F
Is this a EXP119 Engine or the standard IO390?
If this is your first flight, I think you may need to run it a lot harder for breaking period. With that MAP and RPM, I can't imagine you are going very fast which also brings the oil temp up.
It is worth double checking your baffles and timing to make sure all is correct.
Congrats on your first flight.
