lostpilot28
I spent the better part of last night reading the multitude of threads here on VAF regarding inlet/outlet size ratio in regards to improving cooling drag and lowering CHT and Oil temps. I also spent a lot of time recently researching getting a larger oil cooler. I'm beginning to think that a larger oil cooler may not help me.
My "problems" are slightly high CHTs (typically around 385 degrees cruising at around 170 mph TAS, in 83 (F) OAT). I also suffer from "high side of normal" Oil Temps around 215 (F) which creep up to the high 220's if I increase the power setting. If it's hotter outside things start getting even warmer under the cowl.
One thing I noticed that makes me think my cooling problem is related to my exit airflow being too small is that I can see a very small amount of oil exiting the side of the cowl by the upper/lower cowl seam. I guess this is the only silver lining I'll get for having a slight oil weep...but it appears to indicate that my exit air is not sufficiently large, and my bottom-half of the cowl pressure may be too high. Now I'm thinking about louvers instead of a bigger oil cooler. I'd really hate to cut into my nicely painted cowl for something that may not work, though!![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
There's so much information on these related topics it's pretty tough to figure out which direction to start in. I considered removing the upper intersection fairing to increase the exit airflow, but I don't know if that's a good place to start troubleshooting. I'm appreciative of any suggestions on where to start.
My setup is an RV-7A, ECI 0-360, carbed, Catto 3-blade prop, Sam James cowl and Plenum, dual P-mags, piston skirt squirters, Niagra 20002A oil cooler. My temps aren't horrible, but I'd like to lower them a bit if possible.
