Cadstat
My IO-320 doesn't like the heat. It coughs pretty bad on a long 'after flight' taxi back to the hanger. It's about 95F on the ground. Is there anything to be done? I've heard insulation on the spider doesn't help because after a trip through the mechanical pump you have already heated the fuel. Don't like it but I have to run a little higher RPM and heat up the brakes. It's more pronounced in this plane than others I have owned. Any Ideas?
