Are you asking how to handle break in because you are concerned about corrosion? Or are you asking how humidity affects the break in process?
I’ll answer both: fly it every day until it’s broken in and then change the oil and corrosion won’t be a problem.
Humidity has a negligible effect on engine performance and won’t affect the break in process.
