I'll try to ans. questions. We have a four port egt on the Dynon D180. Will temp. rise from 1540 wot level flight by leaning, NO by pulling mixture control
to the point where we get temp. rise at lower power settings it only starts to run rough and temp. seems to be peaked. We do get a temp. rise on one mag. at a little lower power setting but not at wot where we have the condition. I flew this morning to get more info and at 2500 rpm the egt was 1380 and I could lean to 1440 when eng. ran rough and at 2400 rpm the temp. was 1280 and peaked at 1380, but this was at 7000 ft. Was to turbulent at lower and I was having a hard time writing, should get a recorder.
At the beginning of this I should have told that I reamed the main jet nozzle in increments of .002 and .001 to .005 larger in other words from .088 to .093
This carb. is not the part no. for the 0-320 E2D but I went thru it and installed the -813 jet nozzle that is called for and also checked the venturi. I am thinking we have a mild condition of our old hot rod days where we had to put the carb. in a box when super charging (remember that guys). Also I just talked to Glassair owner and he said his air box has a large hole in the back side. When I apply carb. heat the manifold press. drops .8 in. and if I let go of the lever the air press. opens it. The question was asked, where was the mixture control during this, it was full rich.
Looking for your input. Thanks
Ted and Tim Farmin
28 hours
