jacksel
My RV-7 now has about 50 hours on it so I'm assuming the engine break-in is complete (it consumes very little oil). However, it still has CHT's ~ 20-30 deg higher than I see on my RV-6 (13 years and 800+ hours). My RV-6 has dual UNISON LASAR ignition and my RV-7 has Slick impulse mag powering the bottom and LSE Plasma 3 powering the top. Other than that the power plants are identical (Lycoming O-360 on the 6 and Superior XP-360 on the 7). If anything, I would say the baffle installation is better on the 7. As far as I know the cowlings are identical. So I am at a complete loss to understand why the difference in temperature. The 6 maintains ~ 300 deg in cruise and perhaps 350-380 in climb, depending on OAT. The 7 is 370-400 in climb and 320-350 in cruise, but temps seem heavily dependent on whether I lean and how much. I've been running the FF higher just to keep the CHT's down. Also, the 7 CHT's are very balanced and moderate on the ground and the imbalance and significant increase occur after T/O. Generally #2 runs 30-40 deg hotter then #3 and 4, and #1 runs 10-20 degrees hotter than 3 and 4. 3 and 4 run the coolest and are generally within 10 degrees of each other. I have a small baffle dam in front of #1 cylinder and none in front of #2. I started with fairly significant dams in front of both, with my modifications making little difference. At this point the baffle systems of both airplanes are essentially identical.
Any thoughts or other input would be greatly appreciated.
I think it is easy to assume the baffles are identical by appearance, but are they identical in Delta-P?
Hook up a manometer to each and verify they perform the same.
Well, I am no expert engine guru but here are my thoughts. The temps you mentioned are well within the "good operating temps" for the engine. So I am not sure it is necessary that you worry too much about the differences just yet. I personally would not worry too much about the differences in the two airplanes. 800 hours on the RV6, 50 hours on the RV7. As long as the temps remain within acceptable limits for the RV7, I would say, re-visit the question when the RV7 has 800 hours on it. At that point you could see how it compares then to how the RV6 is doing now.
I have to plea complete ignorance here. I honestly don't know what a "Delta-P" or a manometer are.....But I will look into it:confused
"Delta P" is the difference in pressure from the high pressure side of the baffles to the low pressure side of the baffles. In other words, the difference from the top side (high pressure side) of the engine to the bottom (low pressure side).
A manometer is a tool to measure the difference.
Basic check-list
1. Check timing accurately
2. Run tops on auto plugs if you can - NGK BR9EIX work well
3. Check and fix any - I mean any, gaps in solid baffles with silicone
4. Check ramps and nose silicone flexi baffles for seating
5. Check and increase if nec the exit area at the lower edge of the cowl
We dropped our cht's by doing the above. We run mid 300's now most of the time.
I wonder what the spark advance difference is between your old and new?
The old Unison system may still have had less advance than the LSE.
Especially when ROP, this drives CHT up but even LOP it does, however a bit of advance when LOP helps.
The big problem with all these things is finding the balance. Theta PP is what matters and unless you measure that it is a bit hard to control.
Perhaps you need to dial out a couple of degrees on your LSE system. Easy to do with the magneto replacement unit and a bit harder with the flywheel sensor, but it can be done.
