This one is a pre LEMO jack system. It is an interface module with a different connector. The module has its own electronics for volume and on/off and is connected by a flat white connector that plugs into the back of the control module. I’m converting from this to a new LEMO jack.
It’s a LEMO jack. Should be able to find a schematic online searching that until someone can post a schematic. I don’t have it on the phone I’m using.
Stein had it: http://www.steinair.com/wp-content/uploads/2016/03/Bose-Page-1.pdf
