Aussieflyer
Active Member
I'm attempting to join the firewall assembly with the muffler shroud and bottom skins, as per page 28-05.
I've got good alignment except for the curves of stainless steel firewall where it meets with the curves in the stainless muffler shroud. The top four holes do not align miss by about 3/16. The vertical holes align. Naturally if I align the top four holes the six vertical holes miss alignment. Has anyone had this issue and what do you suggest I do to fix it?
