Badger1220
Member
So I to have fallen into the dreadful dilemma of the minimum edge distance on the HS-404 tab using the HS-405 holes that I drilled earlier in the build sequence.
From the picture the hole need to be where it marked in red rather than were it is drilled. I have not drilled through the HS-702 front spar yet so do I reorder a new HS-405 at this point? Or can I take one of the two doubler ?s I made and use it to drill the hole where it should be? Of course I would need to step up the length of the rivet if I used the doubler option.
Open to any and all comments.
https://plus.google.com/photos/1046...s/5874354886739152881?authkey=COXU6ZrQ5qClpQE
