Omega232Devils
Meeting with my engineer to finalize the blueprints for my hangar/apartment in 2 days.
Here are the givens:
60x60x14 Wood hangar with 4/12 roof and flat ceiling inside. (Hangar door oriented to the north on the Grass Runway)
30x30 apartment attached to the west side
50x14 Higher Power Hydraulic Door
10x12 RV/Boat access door (Don't own an RV, and no plans to own one)
2 x pedestrian doors at each end
4 x windows, 2 each along east and south side walls
Here are the maybes:
Insulation - (most important) current plan is to spray in closed cell foam.
No A/C planned, but 2 large fans to move the air around.
Heat - Current plan is radiant tubes hung from ceiling.
Electrical - I plan for 220v or 240v for Hangar Door and workshop, otherwise nothing special.
So, what do you recommend?
What did you do that you are glad you did?
What did you do that you do not use?
All recommendations are appreciated.
Many thanks,
Dan
Many thanks,
Dan
