caapt
How do you rivet the middle section of the tail top skin. All I can think of is to hang it from a tree and stand inside to buck the rivets. Thoughts on how to hang it?
I'm still missing something
How do you keep from bending metal crawling inside. I am not a petit guy.
Caapt, that's exactly what I did. I used a hoist in my hangar and actually lowered it down over my bucker, tail in the air. Had it resting on benches so it would not move around . Worked great.
I had a post a while back but had no luck finding it.
Problem Solved
Put an eye bolt in aft tiedown plate. Hung the tail from the ceiling of the hangar. Bucker stood inside. Worked well. Barely had enough floor to ceiling room.[IMG} www.flickr.com/photos/63734710@N08/16469808185/[/IMG]
