rjcthree
First, my reports have all been good ones, no reds. It’s a -327 tied to a GDL-82, all good. I have notice on most of my reports a slight variance in baro alt delta at 0.10%. Everything else is 0.0% failure consistently. The users guide suggests baro alt delta is the result of a computer calculated plausibility error between reported altitude and baro alt, and seems to assume it’s a baro error. Three questions. Do I have the description correct above. Do you know what error level % Causes a fail? Is there any improvements I need to make? Thanks.
