I do want to be clear.
I was typing from crackberry on previous post so it was short.
I do want to describe my ordeal for everyone.
Started by hand. It went in a little, maybe 1/3 of the hole depth but never peeled a "chip". The cuttings were always small flecks like grinder dust suspended in oil. Worked up a real sweat getting to that point and knew I could never complete the hole that way. I was leaning on the ream with all my weight and turning it with a 18" cheater and using various cutting oils settling on sulpherized oil.
I tried a slow speed drill motor for a minute or two but that went nowhere and nearly ruined my drill motor.
I step drilled to relieve some load. The drill shavings were very indicative of brittle failure of hardened steel. Pretty much trashed the HSS drill bits I used.
SO, I jigged all this into my milling machine so I could use the quill to apply pressure. I worked the hole for a couple of hrs of cheater bar sweat and less that 1/32 progress before snapping the ream in half and NEVER curling a chip. All I got was dust.
So. Everybody says I dulled the ream. I ordered a new one and snapped it in about 5 minutes. Same non-curl chip. I tested the broken shard on 28Rc 4130 and it cut like butter, almost with fingers.
So.. Go ahead and try it. I was not lucky enough to find a carbide helical ream when I was in the throws of this work. I gave up and EDMed the holes. They came out great, but the whole ordeal cost me over $500 before it was over. This included 3 reams from ACS plus the pin hardware, 3 EDM jobs and the time and effort to make an EDM jig for the main gear legs to get the pins in the right orientation because the first hole I partially reamed was a battle zone and create drawings for the EDM guy to CAREFULLY follow.
I still say this is not for the faint of heart. I came VERY close to pitching the legs and ordering them new from Van again.
If the legs were 10 or so points softer in the Rc scale, the job would have probably gone without a hitch. I contend that the legs have a higher heat treat now than they did years ago. It helps with ultimate tensile strength and may have been revised over the years. Mine are roughly 2008 vintage.
**EDIT - See e-mail from supplier Richard@Langair below. Leg hardness has not changed. In that case, I tip my hat to the gents that have sucessfully taper reamed these legs with standard tooling.**
