N834ST
Member
Fellow aviators,
I am in the process of retrofitting my G3X touch, with a GEA24 as the G3X won't talk to my Aerosance FADEC, despite it putting out a useful RS232 data stream. This means I need to double up on sensors because my FADEC is using a bunch right now including EGT, CHT, oil temp, oil pressure, fuel pressure, inlet temp.
Some things are easy, like just adding a second set of EGT, oil pressure and fuel pressure senders but the struggle comes when there are no other places on the engine for sensors. The key one is oil temp. I have only one port that I know of that is suitable for oil temp probe and it is already taken. I have an IOF-360 with a right angle oil filter adapter. The other one, which is just optional but nice to have, is CHT. As you know, only one bayonet fitting per cylinder.
Does anybody have enough knowledge to suggest other options for oil temp location? Can I use the galley plugs on the front of the engine?
Thanks for any help you guys can give.
Mark.
Mark.
