AJ85WA
Hi Guys
Firstly i am running a 160Hp O-320 E2d on my RV6. The engine has a custom cooling plenum already fitted instead of baffles, So mounting on the firewall is the go.
Temps over here are between 70F and 100F
My Question to all you engine nuts out there.
With my engine purchased I received the larger Positech 20004c cooler, I also have the smaller Vans supplied cooler 20002A with my FWF kit.
I need some help selecting which one to use....
Using the smaller one
1. would make my install so much easier as i already have a firewall mounting kit for it
2. and weighs about half the amount
The positech is obviously a lot better quality and bigger to provide more efficient cooling but is that a good thing ...... I would obviously have to install a vent to adjust if it overcools, is it all worth the effort or should i just stick with the vans supplied one?
