wirejock
I'm sure there's a trick. At least I hope so.
The center and aft fuse parts are joined at F706. No problem.
I clekoed the skin to the F704 assembly but the line of holes at F706 is off. The skin is a 1/4" below the aft fuse edge and all the holes are off by that much. I tried lifting the tail end but the whole fuse comes up.
Also, where does the longeron fit at F704H? It must be flush to the skin and ride on top of F704C/D but not sure.
Aggravated and time to ask instead of making more scrap.
