Planecrazy232
I went to perform the service bulletin for the leaking sensor issue and step #1 is writing down the part numbers of the sensors. I went as far as removing them and there is no identification at all on mine (Garmin G3X Touch system).
What are these?
X-IeWbbF9dxN6pFcXnaQm6tSCxvGbKUijnURHQ4GalZbR1efX5tkvWle1oNn-pTF_gzu8vNkQePownge2x30Kg7gvrVyxXnTatIKDWBsMz36G21hLQXDCfgYf-vMrFH-nca1tYFTRhP30QhxQi5j5JJpBiDrdrB6qkYm5SvRkiOrZcJDAxsS26FglFoSksszz6QgLmijb5tfkWunZF5NbJAVvfsKOKczd_Z3k2TtXOqWeu-9Z6Ft89er849_94vWoX67bzIgq3SJOqKD6qubucrnNwgcq4wfE9V0OiKf8HanZv4hTbIMGS7oYxeGJW8PQ26ZrsuhaeYHMN7SxHNhJZ9ZDziVt9VKabf5AFrn1N4AT9G4Ur9vzr5Vns6ACu2kcVdayNNXSd78zEUiUdZf-6XYdLvP_zoXNW-lUd5p-RgzNEU1QP9S3yQY4fRgeG0hVW9io22VmJNGEnz-T2UJ4eImm4KruvXMHerJB1wAAN6Sy0KJ0o6k1jkfF1WGHewaEFc5rRAx9QILSH6Bne7xYh4cN92tJSFafaQPWfjyv2vfmTmLVhUcNd1OJM8ER-bkNPFGJcgB_VyVegwuA58emSjFuGsWXzekX5_127D8xB7wouIHqSMVYAV8CSlP9FnbJgQnqWjwi29OVBwfy32ACXKsYbkazUnPdnw4IMcarBqQGCMthhOdzKWP6B5aLiI=w1292-h970-no
All 3 of those are Kavlicos. If you look hard enough you'll see stamped part numbers on the flats.
8xgRCBorzEIhMMJ8J4uQVhqzvfBSgNkGi56RnIEaOwBaYLLVOct36QM2aG9s4FXOK9mYgMXTpQgoFV1yxBOxOXiO2i5Vr0jdRrjZBI3gpHcGWYpMHjPUpt49cQ7d7hT-ZY-2E9VPOrBaZrYBZtq6rJEtiVqycrdPUnbXmcCwy3A9q4OHjz1nYvIdtB5WEEJfaU-tDPDzxWjGI-uRATzun83_QxeRWTuvF17Y2PmG50_fCjps7741qRky72yMnDzAN4LUhAyKrrDG1skLqmCv2fdSWNxYfN8GeSh5IKygM6AYD_KWdPOb_40A2LLuVE46rLZN7QhicBpBsQBOFR7-cahYrFSYQgYXTmQ5NNyJYmPmajcXYFoRXWPPtDYX6yBhFv1ZaLCXV0pShlK_U8KAOyIrs5T7gaozXRFxflstB843YGODCARvsn9brkAb_1SsJK6se55_ZrzzsVkLX6Nlr1vg7xzxwmWXAkk-zW-ccG8N2Nk6nM8_20fOHEqgCz3JLTUKcguoYTMFE9BAsc5ku-c52Oj7T-ftQHL9yg75F8-_jRIODA5I1MHWDisdQ4JjqK9Yyc-QmMugbvcMpUuXNklUcrfSLofxyA1hgYgBeZPlpBhbSqEgZuIl8ZYCXnZg-uqo79vN37JPvY5HTT1AN8sCnAZtoXmSdlQUqZaK8pLp7bixQbvYz37Lkb_70VbPv-RdL3hNrVzBRcYL6ERnrEuk8AVoDh51zS0ryE4MoKAhcUWuJxs5=w480-h640-no
That would be a bit disheartening as how do you know which pressure rating sensor you have installed.
My sensors that came from Garmin all have similar part# stamp as it is shown in the picture.
