I'm putting out a call for help. After a couple of days enjoying Taos NM, including a sight-seeing flight yesterday, I came out to a small puddle of oil under my RV4 (O-320). Pulled the cowl, searched around, put a wrench on fittings (all tight), cleaned it up and decided to do a runup to try to determine source of problem.
Ran rough. Yes I leaned it for the high altitude...got a nice smooth increase in power there but otherwise moderate roughness. The oil pressure took just a second or two longer than normal to come up. When it did, it was significantly lower than usual. Normal is top of the green, 80#, now all it can do is 60# (bottom of green).
I am beyond my level of expertise so I need help. There are no A&Ps on the field. Closest according to lineguys are in Alamosa or Santa Fe. Any and all help or suggestions would be greatly appreciated (and financially compensated)!!
Cell 620-755-3883.
Cell 620-755-3883.
