flyingRV
Member
Hi,
sorry I postet this thread accidentally in the RV12 forum, I closed it there as I haven't found the possibility to delete or move the thread to another forum.
At first thanks for this great forum and for all the information I've already found here.
I'm new to this forum so a short introduction. I live in the northern part of Germany, 38 years, married, 2 small kids and have been flying since more than 20 years. At the moment I own a 4-Seat Vintage Taildragger but decided to sell it and build my own plane in the near future. It should be a 2-Seater as I seldom use the 4 seats.
There are a lot of options nowadays but for me as a first time builder I'd prefer a kit with great builder support and a company behind it which already is in business for some years. So at the moment I have the following aircraft on my list.
RV9, RV12, Europa XS and maybe Rans S21 (maybe too new to get enough support).
My mission profile EXcludes aerobatics. I just need an efficient aircraft, carrying 2 people (together around 330 lbs) for around 500NM at a reasonable speed (at least 110kts) and take some baggage (including tent and sleeping bags) for longer trips (at the moment maybe a weekend only but in the future when the kids are grown up, let's say 1-2 weeks). I know, everything is a compromise.
Although I appreciate comments on the other planes as well, I would stick to the RVs here. The 9 - on paper - would be perfect for me. But I'm wondering about the long build time and the Lycoming. I trust the old engines, no question, but they are more expensive, don't fly on mogas with ethanol, and I always have to order more expensive parts from the U.S. instead of driving to ROTAX. I want to make as little changes as possible to the design so another engine is not an option for me.
I like the 12 more and more but have some concerns.
Can somebody post the dimensions (not the volume) of the baggage bay in the new RV12is and in the 9?
Vans mentions a volume of 5 cubic feet in the 12, this seems to be little tight.
I have found nearly nothing about the touring capability of the 12.
I calculated the W&B for the "old" RV12 with the sample data of the POH provided
by VANS. With only me (185lbs) in the cockpit it seems to be impossible to load any baggage when the tanks are full. Also with my wife it's impossible to make use of the 75lbs in the back. And if I put the 912 instead of the 912is in it it will even become worse I think.
Can you confirm that the 12 is so trim critical?
I've never flown a VANS yet but I hope to get a demo flight on my first visit in OSH this year.
Thank you so much for your help.
Simon
re. "Old RV-12" weight & balance
My "Old" RV-12 came in at:
759.5 pounds empty weight (inc. autopilot, lighting, ADSB, interior trim, fire extinguisher, breakout hammer, excl. wheel fairings)
10.0 pounds for the wheel, leg and intersection fairings
7.0 pounds other stuff I always carry (tools, Decalin, quart of oil, etc.)
I weigh 210 pounds, 140 for wife. That gets me to 1126 pounds. Adding 120 pounds for fuel gets me to 1246 pounds leaving 74 pounds for baggage (the baggage compartment has a max of 50 pounds).
With that configuration, the C.G. is admittedly at the aft edge of the envelop but still within it. I've flown it at max gross weight with the C.G. at the extreme aft edge without any problem, it was quite comfortable.
Van's shows the baggage bay as 12+ cubic ft. & 75 pounds on the RV-9. You should also remember that the RV-9 prototype was built with a 118 hp Lycon from a Cessna 152. It still had great performance! Even with the small engine the cruise speed at gross weight is 164 mph.With a 160 hp engine the gross weight cruise speed on the 9 is 186 mph!
The RV-12 baggage area is shown as 5 cubic ft. & 75 pounds. Since the RV-12 was built with the LSA limitations in mid, top speed regardless is 136 mph.
The 12is is an easier and quicker build, no doubt about it. It's also a lighter aircraft as it is built for LSA standards in the US. Everything in the plans is laid out for you and it leads you by the hand all the way through. The 12 uses pulled rivets and there is no drilling a smaller hole into a slightly larger hole in the build process. As a matter of fact because its a lighter plane the skins are thinner. You don't even need to dress each hole. If you do you have to be careful not to thin the metal even more. The 12 is more of a cleco the parts together and pull the rivets kind of build. The real advantage of the plans is if you build everything the way Van's wants it built; engine, panel, etc. If you stray from that then you are on your own in those areas just like on most of the other models.
The plans on the 9 are not as advanced as the 12is since the 12 is a newer aircraft. Van's sells the plans separately on their website and they come on a USB drive and full of pdf's, etc. The plans of course come printed out with all of the kits. The 9 kit requires more work, it is a larger plane and has more options during the build.
The plans on the USB drive run $10 for each model. You don't have to be a builder to pick up the usb plans sets. http://vansaircraft.com/cgi-bin/store.cgi?ident=1523885651-436-471&browse=videos&product=fd_plans. I'd really recommend you grab an RV-9 and an RV-12is set of USB plans and look them over.
There is nothing wrong with either plane, or any of Van's aircraft for that matter. I'd much rather build a Van's kit than any other.
Which one you build is best answered by you and your mission.
A few lifetimes ago, I started with the emp kit for an RV-9 (they were all nose draggers back then). I had never done anything like this before. My wife and I took a class on building a Van's kit one weekend and the next thing you know we had a tail section built. The 9 plans were the most advanced plans set at the time.
Life got in the way, I got older and concerns about a medical left me building an RV-12 because of my ability to still fly an LSA aircraft in the US. We built most of the kit (she should be flying by now) and we really enjoyed it. I beat the medical issue and now I'd think I'd love to get back to that 9.
Which ever choice you make you can't go wrong. It's a Van's kit after all!
Bob
I built and Fly a RV-12. I chose that because government regulations in the USA allow me to fly it without having a medical exam.
I would rather have built a RV-9 which has better short field performance and better cruise speed. The RV-12 has flaperons, not separate flaps. The RV-12 floats and floats on landing unless the pilot has precise control over the approach speed.
I think that you made a mistake calculating weight and balance for the RV-12. The pilot and passenger sit forward of the CG. Balance is not a problem. The biggest issue is gross weight.
Have you considered an alternative engine in the RV-9? Perhaps the UL Power? The RV-9 will definitely take longer to build. The RV-12 goes together very quickly.
My take
I am building a 9A now. My take is if there is a concern about medical, then build a 12. If medical is not an issue, then build a 9. The 9 is much more capable and has a larger future mission capability, namely IFR and high(er) altitude cruising. If you really get into traveling, the IFR ticket will be the natural progression. Some argue the RV12 could be used for IFR, but this is really skirting the rules and sanity, in my opinion. JMHO
Simon,
The baggage area volume listed for the RV-12iS is for the space that is below the cross member that the seats lean against (16" X 41" X 13" deep). If the interior area available above that, that can accommodate softer / lower weight items is included, then the total is more on the order of 12 cubic feet or so.
I agree with others that you must have made a calculation error when doing the sample weight and balance. A typical RV-12 with full fuel and 50 lbs of baggage can accommodate two 190 lb people and be just a bit fwd of the aft CG limit. Because the location of the fuel tank is aft of the C.G., the C.G. moves fwd. during the flight as fuel is used, rather than further aft like many other aircraft, so the C.G. at take-off will always be the most critical condition but if the baggage weight limits are observed it is impossible to exceed the aft limit.
Because the new RV-12iS carries its fuel further fwd than the Gen1 RV-12, it allowed for raising the baggage area weight limit to 75 lbs (assuming the weight of the occupants allows for it while staying at or below the 1320 lb weight limit).
Thank you very much.
The build time, the Rotax and the price are the advantages of the 12 for me.
We here always need a medical, no matter what Aircraft you are flying (ok if it has less than around 230lbs empty weight then you can do it without).
I don?t want to put the plane on a trailer, we are not allowed to fly IFR.
So some of the points don?t apply to me.
I checked my Numbers for W&B again. The problem is not the fully loaded Aircraft but the flight where there is only me (180lbs) in front of the spar and 20 USG+75lbs of baggage behind it. I also checked on a spreadsheet from the Internet...same result. For landing it?s getting better of course but takeoff is out of cg Limit.
If I?m ok with the smaller baggage (thats why I asked about the touring capability) and the CG the 12 ticks the boxes. But to be ?save? in all aspects the 9 would be right, with or without the small engine, but it?s a question of build time (so I don?t want to put another Engine in it) and money.
Hi Simon,
Welcome to these Vans Air Force forums :D
When I was looking at building an experimental aircraft a few years back, I spent about 2 years studying dozens of models, before I narrowed the search down to a Europa XS or Vans RV 9A, 7A or 12 models.
I really liked a lot of things about the Europa - auto fuel, good cruise speed and fuel efficiency, nice looks. It turned out that when I joined EAA Chapter 309 in Charlotte, NC a few years ago, there was a nice English gentleman who was a member and he built/flies a Europa, and he was kind enough to take me for a flight. The result: I really liked his Europa...but I am six feet tall (1.82 meters) and weigh 170 pounds (77 kg) and unfortunately found that my head pressed uncomfortably against the cockpit's ceiling. Bummer, because it is a neat plane otherwise.
I was at Sun-n-Fun this past week and spent a lot of time checking out the new Vans RV-12is and asking lots of questions. One thing that I noticed on the new RV-12is is that the opening to the cargo area (between the top of the fuel tank and the roll bar) is a little tight - seemed like it was about one foot tall (0.3 meters) or so, if I remember correctly.
I think the new RV-12is might be an excellent plane for your described mission. Heck, I'm even thinking about building one now instead of a larger RV!!! There really are a lot of things to like about Vans new and improved model!
Hope this helps :D
If flying by myself, I put the heavy stuff in the passenger seat to keep things closer to CG. This should work for you in the -12 as well.
If you wish to carry a full 75 lbs of baggage but are solo, you can strap a heavier portion of your baggage into the front passenger seat with the 5 point harness
If you tilt the seat backs forward (easy to do) there is vertical clearance of 18" (it is actually closer to 20" but if you account for the cabin light and the latch block for the canopy latch, it is a totally clear space of 18")
After getting so many replies before. I want to keep you up to date.
Back from OSH I'm as far as before concerning my decision.
At first, I've spent a lot of time browsing through the homebuilt area and the guys of VANS have been very friendly and show a lot of patience.
I was lucky to get a demo flight in the 7 and it was - of course - great. To remember, I was pretty sure to decide between 12 and 9, but after flying the 7 and sitting in the 14 I was completely lost :)
I loved the space and the look of the 14, the efficiency and comfortable cockpit of the 12 with a great visibility, the performance of the 7 with 200hp. I have read so many times about "Defining the mission" and there is nothing more difficult than this. On the one hand, there are the things you do right know and on the other which you'd like to do. I was a little disappointed about the visibility and seating position in the 7+9. There is a big difference compared to the newer models.
I was pretty sure to return home and be sure which airplane to build after having seen all the kits in real life...
But it was nevertheless a great trip!
Simon,
Sorry you missed the Europa forum at Oshkosh. There were about 20 of us you could have chatted with. With the weather, only one managed to fly in.
The LAA rally starts Friday August 31. It is at Sywell UK. There will be Europa Club display and several Europas for you to see. There will also be RVs in attendance.
If you PM me, I can tell you about our Europa.
Let me know if I can be of assistance.
Jim Butcher
One of the problems with LSAs is that if they can fly slow enough to meet LSA requirements, their ability to handle crosswinds may be compromised and the ride in turbulence can be harsh. I see some of the latter in my RV-9A.
Hi again,
after a lot of thinking, researching and talking I narrowed the possible choices to the 7 or 14. The visit in OSH changed my mind, I'm glad I'v made the trip.
I've taken a deep look into the 9 and 12 plans (I've ordered the USB stick some months ago when I was strongly leaning towards the 12 or 9) and of course the advanced plans of the 12 make a huge difference. Assuming the plans from the 9 equal the ones for the 7 and the 12 more or less the 14 I ask myself if it's worth to base the decision on the ease of building.
I'm pretty sure I'll manage to understand the 7 plans but it'll take time.
Let's say the 14 satisfies my "needs" to 90%, the 7 to 80%. Spending >20.000$ more for the 10% and an easier built is a lot.
But the more I look into the plans the more I get the feeling that the most difficult thing is not the airframe but FWF, the electric and the avionic without any instruction.
I understand that the 14 has everything pre-fabricated if you stick to the standard but here comes the problem. The 14 is designed for G3x or Skyview right? There is nothing wrong with that but here in Germany you have to install certified avionic if you want to use the plane for IFR, which I'd like to do one day.
So right now I had to install something else and lose therefore some of the big advantages of the 14.
How did you approach the FWF and electric/avionic installation? If you buy the FWF-Kit including engine from VANS do you get the same instructions like in the airframe plans?
Do you think it's worth building the 14 due to easier built if you have to design your avionic and electrical system yourself as in the 7?
Thanks for your help.
Simon
