db8
![1323223img.jpg](/community/proxy.php?image=http%3A%2F%2Fimg4.imageshack.us%2Fimg4%2F7879%2F1323223img.jpg&hash=d6ecbadb5f556305310cb4b726ddc748)
I purchased this AN5812 heated pitot tube (P.H. 502-12) on VAF about four years ago. Am doing the electrical (finally), and was wondering how I should do the electrical/tube hookup? I hooked up the pitot tube to a battery and she gets hot quick.
ACS has a phenolic connector receptacle for about $60.00http://www.aircraftspruce.com/catalog/inpages/pitottubeconnect.php . I have seen others with this plugged in. I suppose this is required vs connecting the wires to the probe with a regular connector (maybe gets too hot)?
As far as the tube goes, I'm guessing I might have to get a stainless steel pressure fitting (to accept an AN-4 fitting) and get it brazed on?
![pitottubeconnection1ori.jpg](/community/proxy.php?image=http%3A%2F%2Fimg21.imageshack.us%2Fimg21%2F4444%2Fpitottubeconnection1ori.jpg&hash=552c8a897c4c5d560d5f5e1563b291fa)
The main reason for the post is to see if anybody has had to start from this point like I am, and what they did? Don't know where to get the pressure fitting with a tube already connected? Maybe at the local fitting store (Parker). Do I need the phenolic connector? Any previous experience info on this would be appreciated. Thanks. Dave
PS. Is it ok to paint the pitot heat, or will the paint just peel away from the heat? I could maybe bead blast it to clean it up --don't know if it's stainless, but don't think it would rust (can't imagine)?
