Hi,
I?m deciding the best location for the pitot tube and understand it can be hard to place at the plans location (one bay inboard from bellcrank bay) due length of alu tube needed vs aileron pushrods. Note I will likely put it in the rh wing.
For anyone who has installed the pitot one bay OUTBOARD of the bellcrank rib, did you ever find any issues tying the aircraft down? Is this a real concern? (Any photos?)
If this is an issue, is there any reason not to put it further outboard? (AOA issues or big speed variations when slipping etc)
Thank you!
Thank you!
