Blain
Spending a lot of time just pondering the systems. I'm close to the big move to the airport. Want to be as done as I can before the move.
So this just got my attention; heat muff on right side and a heat shield on left protecting fuel line from pump to servo. I'm thinking these should be reversed. The heat muff should radiate less heat then the shield. Only an inch or so clearance shield to fuel line so it could be a toasty zone there.
Thoughts?
Thoughts?
