Hose
Either will work. Lycoming STD 2180 or brand x AEL ST2180 or Aeroquip 303-6 hose and cut your own. For a homebuilt an automotive type clamp will work better than the standard worm drive clamp. If you cut your own I would make them at least 1/4" longer than stock. MIGHT help prevent future leaks.
