If this is truly an F-6 governor, it's a feathering governor, and will work "opposite" from a governor that is normally installed on a single engine aircraft. It might work with the prop you have, but this governor is "pressure to low pitch" and most governors on single engine aircraft are "pressure to high pitch."
